Expedition 1 TSBs и Recalls for '97 Expeditions проверить на реколлы
Automotive Recall and Technical Service Bulletin Titles for 1997 Ford Truck Expedition 4WD V8-5.4L SOHC VIN L.
TSB Number & Issue Date TSB Title
05S28S10 MAR 07 Recall - Cruise Control Deactivation Switch/Fire Hazard
03S02 MAY 03 Recall - Steering Shaft Yoke Defect
00S14 JUL 00 Recall - Daytime Running Lamp Non-Compliance
00S05 MAY 00 Recall - Trailer Hitch Hardware Replacement
00B33 MAR 00 Recall - Airbag Deactivation Shunt Replacement
97S86 OCT 97 Recall - A/T Shift Cable Retention
96S60 FEB 97 Recall - Rear Track Arm/Control Arm Bracket
04L19 SEP 04 Campaign - Tie Rod Inspection Maintenance Reminder
98B33 APR 99 Campaign - Coolant/Cylinder Head Replacement
99B02 MAR 99 Campaign - Multifunction Switch Replacement
97B17 FEB 98 Campaign - Fuel Gauge/Sender Assembly
07-1-7 JAN 07 Steering - Mercon V(R) Fluid Usage
06-21-19 OCT 06 A/C - Heater Core Electrolysis/Leakage
06-19-14 OCT 06 Starting System- No Crank Condition
06-18-16 SEP 06 Engine - Reman Engine Head Gasket Identification
06-14-4 JUL 06 A/T - Mercon V ATF Usage
05-26-18 DEC 05 Suspension - Air Suspension Excessive Compressor Noise
05-23-3 NOV 05 Drivetrain - Rear Differential Whine/Hum Noise
05-22-8 NOV 05 Ignition System - Coil-On-Plug Misfire Diagnostic Tips
05-5-4 MAR 05 Exhaust System - Exhaust Manifold Studs Broken
04-24-14 DEC 04 Engine Controls - General PCM Programming Procedures
04-18-11 SEP 04 Body - Corrosion At Bottom of Door or Tailgate
04-16-1 AUG 04 Ignition System - Engine Misfire Diagnostics Tips
04-5-7 MAR 04 Body - Front Window(s) Pop/Thump Noise at End of Travel
03-23-2 NOV 03 Body - Exterior Mirror Glass/Motor Service Tips
03-20-3 OCT 03 Emissions - MIL ON/DTC's Stored/Check Fuel Cap Lamp ON
03-18-1 SEP 03 Keyless Entry System - Service Tips
03-15-13 AUG 03 Steering - Tie Rod End Inspection Procedures
03-14-8 JUL 03 A/T - Cooler Flushing Service Tips
03-9-2 MAY 03 Air Suspension - Repeat Compressor Drier Failures
02-21-1 OCT 02 A/T - Torque Converter Access Plug Dislodges
02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check
02-20-8 OCT 02 A/C System - Diagnosis and Service Tips
02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling
02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers
02-11-7 JUN 02 A/C System - Musty/Mildew Odors
02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips
02-2-3 FEB 02 Engine - Aluminum Block/Head Machining
02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures
02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications
02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment
01-24-6 DEC 01 Engine - Oil System Priming Procedures
01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations
01-21-5 OCT 01 Engine - High Idle/Sticking Throttle
01-20-5 OCT 01 Driveability - Vacuum Leak Detection
01-16-6 AUG 01 Transfer Case - Multiple Electrical Malfunctions
01-12-8 JUN 01 Air Suspension - Lamp ON/DTC's B2140 or C2140 Set
01-10-12 MAY 01 Wire Harness - Terminal Repair Kit
01-9-7 MAY 01 Emissions/Engine Controls - Driveability Diagnosis
01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers
01-6-2 APR 01 PATS System - Diagnostic Service Tips
00-26-1 DEC 00 Engine - Rough Idle/Noise When Cold
00-23-10 NOV 00 A/T - In Line Fluid Filter Kit
00-20-1 OCT 00 Fuel Pump - Driveability Lack of Fuel Pressure
00-9-1 MAY 00 A/T Cooler - Fluid Leaks at Radiator
00-1-8 JAN 00 A/C - Blower Motor Stays on HIGH
00-1-7 JAN 00 MIL ON/Trouble Codes Stored/Driveability Symptoms
99-26-9 DEC 99 Fuel Economy - Customer Expectation vs. Vehicle Usage
99-25-6 DEC 99 Brake Rotor - Incorrect Discard Thickness Specification
99-25-2 DEC 99 Engine - High Idle Speed/Throttle Sticking
99-24-2 NOV 99 Locks - Lock Service Packages Available
99-23-4 NOV 99 EVAP - DTC's P0442/P0455/MIL ON/No Driveability Concerns
99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure
99-19-6 SEP 99 A/C - Identification of Non Approved Refrigerants
99-19-4 SEP 99 Brakes - Vibration/Inspection Service Tips
99-18-5 SEP 99 A/T - 4R70W TCIL ON/Code P0782/Delayed/No 2-3 Upshift
99-16-4 AUG 99 Ignition Key - Hard To Remove From Ignition Cylinder
99-15-2 JUL 99 A/T - Transmission Flush and Fill Tool Available
99-15-7 JUL 99 Drivetrain - Vibration/Shimmy Above 45 MPH
99-14-3 JUL 99 Front Differential - Moaning Noise In 2WD Mode
99-12-8 JUN 99 A/C - Whistling Noise When Driving With A/C OFF
99-11-1 JUN 99 Comprehensive Noise/Vibration/Harshness Procedure
99-12-10 JUN 99 Paint - Rough Texture
99-9-6 MAY 99 A/T - 4R70W (Remanufactured) Delayed or No 2-3 Upshift
99-8-15 MAY 99 Interior Door Trim Panel - Replacement Tip
99-8-16 MAY 99 Motor Oil - Viscosity Grade Recommendation
99-6-5 APR 99 Side Doors - Wind Noises
99-5-3 MAR 99 A/T - Cold Fluid Level Checking
99-5-4 MAR 99 Frame - Service Kit Availability
99-4-3 MAR 99 PCM - Reprogramming Out of Vehicle
99-2-2 FEB 99 Air Suspension - Underhood Buzzing Noises
99-2-3 FEB 99 Windshield - Water Leaks
98-26-2 JAN 99 Fuel - Volatility Related Driveability Concerns
98-25-21 DEC 98 Exhaust System - Cracks/Breaks Between Muffler/Tailpipe
98-25-9 DEC 98 Interior Trim - Vinyl Surface Repair Tips
98-25-4 DEC 98 Suspension - Warning Lamp ON/DTC's C1770/C1845
98-24-6 DEC 98 Electrical - New Terminal Grease Released For Service
98-23-9 NOV 98 A/C - No/Intermittent Auxiliary A/C Mode/Blower Control
98-23-25 NOV 98 EVAP Line - MIL Illuminated/Trouble Code P0455
98-23-10 NOV 98 Engine - Lean Driveability Symptoms
98-21-21 OCT 98 Engine - Fast Idle Speed/MIL ON/DTC P1506 Set
98-21-17 OCT 98 Parking Brake Control - Rubber Bumper Stop Available
98-20-10 OCT 98 Exhaust System - Buzzing/Rattling Noise
98-20-19 OCT 98 Power Seat Switch - Button Comes Off
98-18-2 SEP 98 Paint - Materials For After Warranty/Warranty Repairs
98-18-7 SEP 98 Steering/Driveline - High Speed Vibration
98-17-21 SEP 98 Body/Frame - Squeaking/Rattling Summary
98-17-1 SEP 98 Seat Leather - Cleaning Procedure Tips
98-16-8 AUG 98 A/T - Main Controls/Separator Plate/Gaskets Usage
98-16-9 AUG 98 Alignment - Toe Setting Procedure Tip
98-16-12 AUG 98 Fuel Rail - Fuel Leaks At Spring Lock Coupler
98-15-12 AUG 98 Evaporative Emission Canister - Components Availabilit
98-15-15 AUG 98 Front Suspension - Clunking Noise
98-13-13 JUL 98 Front Leather Seats - Wear Prematurely
98-13-15 JUL 98 Running Boards - Too Narrow When Exiting Vehicle
98-12-5 JUN 98 A/C - Filtering Refrigerant After Compressor Replacement
98-11-7 JUN 98 Rear Axle - Chattering On Turns Or Cornering
98-9-20 MAY 98 A/T - E4OD 4-1 Downshift During Forced 4-2 Downshift
98-9-15 MAY 98 ABS - Lamp ON/DTC B1342 Stored
98-9-13 MAY 98 Body/Frame - Water Leaks Causing Electrical Problems
98-9-9 MAY 98 Fuel Injectors - Non Warranty Reimbursement Testing
98-7-4 APR 98 Engine - New Gasket Sealer
98-6-13 MAR 98 A/C - Cold Air Felt On Passenger Floor In Heat Mode
98-5A-11 MAR 98 Brakes - Elimination Of Sanding Rotors And Drums
98-5A-5 MAR 98 Hub-Mount Brake Rotor Machining Equipment
98-5A-4 MAR 98 Lug Nuts - Proper Installation/Torqueing Procedure
98-5-8 MAR 98 MIL ON/DTC P0503/Erratic Speedometer/Shifting
98-4-19 MAR 98 A/T - E4OD TCIL Flashing/DTC's 62/628/1728 Stored
98-3-3 FEB 98 Paint - Surface Defect Removal Without Repainting
98-2-7 FEB 98 Air Conditioning - Musty/Mildew Type Odors
98-1-13 JAN 98 Bumper - Rust Staining
97-26-19 DEC 97 PCM - MIL ON/Multiple DTC's Set/Driveability Concerns
97-26-25 DEC 97 Rear Sway Bar Link - Clunking/Rattling Noise
97-25-5 DEC 97 Blower Motor - Chirping/Squeaking
97-25-8 DEC 97 Engine - Rough Running/MIL ON/DTC'S Set
97-24-23 NOV 97 Engine - Stall During Transmission Engagement
97-24-18 NOV 97 Outside Window Mouldings - Stained/Discolored
97-23-13 NOV 97 A/T - E4OD New Case And Extension Housing
97-22-1 OCT 97 EGR DPFE Sensor - Voltage Range Revision
97-22-7 OCT 97 Wheel Hub - O Ring Service Tip
97-21-14 OCT 97 Rear Wiper Arm- Installation Service Tip
97-20-15 SEP 97 Universal Joint - Greasable Design Availability
97-19-19 SEP 97 A/C - No Airflow From Floor Vents
97-19-20 SEP 97 A/T - E4OD Main Regulator Booster Service Tip
97-19-4 SEP 97 Brake and Rotor - Service Tips
97-19-11 SEP 97 Heater Core - On Car Pressure Test For Warranty Claim
97-17-25 AUG 97 A/T - E4OD New Design Reverse Clutch Assembly
97-17-2 AUG 97 Rear View Mirror - Reattachment
97-16-11 AUG 97 A/C - Condensate Dripping Onto Passenger Floor
97-15-21 JUL 97 Engine - Stalls When Transmission is Engaged
97-15-23 JUL 97 Power Window/Mirror/Lock - Right Side Inoperative
97-14-20 JUL 97 Rear Air Conditioning Lines/Tubes - Service Tip.
97-13-14 JUN 97 A Pillar - Wind Noise
97-13-23 JUN 97 A/T - E4OD Slip/Bump on 1st to 2nd Gear Upshifts
97-13-21 JUN 97 Driveline - Clunking or Grunting Noise
97-13-17 JUN 97 PCM - MIL ON/DTC P0446 Set/Stall/Knock
97-13-18 JUN 97 Radio - Whining Noise on AM Band With A/C ON
97-13-13 JUN 97 Rear Quarter Window - Wind Noise
97-12-13 JUN 97 A/T - Low Transmission Fluid/Shift/Engagement Concerns
97-12-10 JUN 97 Blower Motor - Vibration/Noise from Center Console
97-11-11 MAY 97 A/T - AODE/4R70W Erratic/Prolonged 1-2 Shift
97-11-21 MAY 97 A/T - E4OD First Gear Ticking Noise
97-11-17 MAY 97 Fuel System - Slow Fuel Filling/Early Nozzle Shut-Off
97-11-5 MAY 97 Remote Antitheft Personality Transmitter - Reprogramming
97-15-5 MAY 97 A/C - Refrigerant Oil Refill Capacity
97-10-10 MAY 97 Front Axle Tube Vent - Lubricant Leak
97-9-16 APR 97 Fuel Gauge - Erratic and/or Inaccurate Readings
97-9-8 APR 97 PCM - Reprogramming Tips
97812 APR 97 Rear Door Quarter Panel - Wind Noise
97620 MAR 97 EVAP System - MIL ON/DTC P0446 in Memory
97626 MAR 97 Engine - Oil Level Checking Incorrect in Owner's Guide
97410 FEB 97 A/T - E4OD Cooler Bypass Valve Service Tip
9735 FEB 97 A/C - R134a Tracer Dye and Three O Ring Spring Couplers
962618 DEC 96 New Locking Fuel Caps - Available
962612 DEC 96 Torque Converter - Cleaning and Replacement Guidelines
962518 DEC 96 Power Point Access Door - Breaks
962523 DEC 96 Spark Plug Wires - MIL ON/DTCs P0300 Through P0308 Set
962418 NOV 96 A/T - E4OD Forward Thrust Washer Revision
96249 NOV 96 A/T Torque Converter - Leak Test Procedure
96246 NOV 96 Electrical Diode - Identification and Replacement
962410 NOV 96 New Digital Transmission Range Sensor - Service Tip
96228 OCT 96 Front Window - Wind Noise/Run Lip Hanging Out
96225 OCT 96 Mass Air Flow Sensor - Assembly Replacement
96221 OCT 96 Windshield/Interior Glass - Fog/Film
962117 OCT 96 A/T - E4OD Unique Parts Application
96201 SEP 96 Paint - Codes and Colors/Cross Reference
Vetervox
А у меня, как выяснилось, 5 открытых.
03S02 1997 MODEL YEAR EXPEDITION AND F-SERIES UNDER 8500 GVW VEHICLES INTERMEDIATE STEERING S
96S60 REAR AXLE TRACK BAR BRACKET/LOWER CONTROL ARM BRACKET
97S86 AUTOMATIC TRANSMISSION SHIFT CABLE RETENTION
98S14 WHEEL ATTACHMENT - LUG NUTS
05S28 PERFORM PRIOR TO VEHICLE DELIVERY: SPEED CONTROL SYSTEM MODIFICATION
А отзыв, касающийся косяка с круз-контролем, почему-то не отображен. Типа он меня не касается? Кто-нибудь уже к московским диллерам совался за реколлами?
дык последний это он и есть.
Люцифер
ээээ, господа, просветите что это за китайская грамота?
Как понял это отзывы производителя по неисправностям? Или нет?
И что это нам дает?
dwalin
The deathless horsie
2 433
69
гык. у меня тоже три:
ну что, дружно напрягаем дилеров? :)
И что это нам дает?
это дает нам то, что открытые реколлы должны исправляться дилерами бесплатно.
Люцифер
угумс, понял
две штуки
00S05 TRAILER HITCH ATTACHMENT
Beardman
Ну а у меня одна:
токма по ней инструкция для офф. диллеров такая: отключать круиз-контроль нах. А вот когда дядя форд пришлет по запросу от этого диллера ремкомплект (которого как мне сказали в природе пока нет - его придумывают) тады вызывать клиента повторно и ставить ремкомплект.
вот так...
Vetervox
Так как? Никто так и не решился к дилерам обратиться? Или обратившегося дилеры просили об этом никому не рассказывать? :)
Vetervox
Звонил сегодня в Рольф. Сказали подъезжайте, правда записали аж на 28 октября. Может еще какому дилеру позвонить? :roll:
Vetervox
Накануне визита к дилеру, решил проверить открытые отзывы на свой агрегат на сайте
http://www.ford.com/owner-services/customer-support/recall-information
Так удивительное дело: список из пяти открытых реколлов волшебным образом сократился до одного пункта - 05S28 (круиз-контроль). :roll: :?: :?:
странно.... из могут отменять что ли? или дилер в испуге взял и отчитался перед центром? :)
Vetervox
2Dwalin:
Смотрю, у тебя, как и у меня, тоже был открытый реколл 03s02 (03V196000). Если ты его у дилера не закрывал еще, проверь, пожалуйста, на сайте ford.com - он за тобой еще числится?
А то от дилера был сегодня звоночек по телефону типа: "Вы приедете? Вас ждать?" и т.д.
В конце разговора попросили назвать или поскорее прислать VIN, чтоб "успеть обратиться к базе данных". Ну я прислал.
Проверяю открытые реколлы - из пяти один остался...
Вот в голове бродят мысли всякие нехорошие :evil:
ЗЫ.
2CodeX:
А у тебя список реколлов не изменился?
dwalin
2 433
69
не, похоже что дилер ни при чём. я никуда не звонил, не записывался, но мне щас тоже только один реколл показывают, про круиз-контроль. в потолке открылся люк. :(
Vetervox
Или у Форда открылся жаб...
Эээх. Как там FORD правильно расшифровывается? Fix Or Repair Daily? :D
Vetervox сказал(а):
2Dwalin:
ЗЫ.
2CodeX:
остался один:
Open Recalls
Recall: 05S28
Description: PERFORM PRIOR TO VEHICLE DELIVERY: SPEED CONTROL SYSTEM MODIFICATION
я так мыслю что срок давности в 10 лет прошел :)
нет дефекта - нет реколла :)
Vetervox
хуясее. Форд жжот. Реколл 03s02 он же от 2003 года...
Mr.Miller
Народ, а посвятите меня необразованного что это вообще такое?
Зашел по ссылке и ничего не понял... Чего вообще делать то надо??!!! Можно подробно с инструкциями, а?!
И еще, а вот если у меня машин сделан для европы, то эти ваши реколы вообще прокатят?!
Mr.Miller
А разобрался ка проверить!!!
Рузельтат: Open Recalls
Recall: 05S28
Next Steps
Locate your local dealership to schedule a repair appointment or to obtain detailed part information, depending on the nature of the recall.
Advise the service department of your local dealership of your open recall information:
05S28—PERFORM PRIOR TO VEHICLE DELIVERY: SPEED CONTROL SYSTEM MODIFICATION
Set up an appointment to have the recall completed.
и что теперь с этим делать то?
и что это вообще значит?
