блин...
вот это все для кого выкладывалось?
http://www.ford-trucks-club.ru/forum/dload.php?action=category&cat_id=8
Для тех кто не может найти это в мануале:
Speed Control (If equipped)
If your vehicle has speed control, you can automatically maintain a constant speed at or above 30 mph (50 km/h).
To set the speed control:
1. Press and release the ON switch.
2. Accelerate to the desired speed above 30 mph (48 km/h) using the accelerator pedal.
3. Press SET ACCEL switch and release it immediately. This will set your speed. If you keep this switch pressed, your speed will continue to increase and will not be set until the switch is released.
4. Take your foot off the accelerator pedal. Your vehicle will maintain the speed you set.
If you drive up or down a steep hill, your vehicle may momentarily slow down or speed up, even though the speed control is on. This is normal.
Accelerating With the Speed Control Operating
You can use the accelerator pedal to speed up momentarily.
When you take your foot off the accelerator, the vehicle will return to the set speed.
Resetting the Speed Control
To reset the speed control to a lower speed, press and hold the COAST switch. Let your vehicle slow down to the desired speed and release the COAST switch.
Your vehicle has a “tap-down” feature that allows you to decrease your current speed in increments of 1 mph (1.6 km/h) by a momentary tap of the COAST switch. Multiple taps of the COAST switch will decrease your vehicle speed 1 mph
(1.6 km/h) for each tap. For example, if you are currently set at 65 mph (104 km/h) and tap the COAST switch 5 times your vehicle speed will decrease and set at 60 mph (96 km/h).
To reset the speed control to a higher speed, you can follow any of these procedures:
n Accelerate to the desired speed, then press the SET ACCEL switch and release it immediately.
n Press and hold the SET ACCEL switch, then accelerate to your desired speed and release the switch.
n TAP-UP — This allows you to increase your current speed in increments of 1 mph (1.6 km/h) by a momentary tap of the SET-ACCEL switch. Multiple taps of the SET-ACCEL switch will increase your vehicle speed 1 mph (1.6 km/h) for each tap. For example, if you are currently set at 60 mph (96 km/h) and tap the SET-ACCEL switch 5 times your vehicle speed will increase and set at 65 mph (104 km/h).
Turning the Speed Control Off
You can cancel the speed control while you are driving.
n Press the OFF switch. The speed control is off. If you want to resume speed control, press the ON switch and reset the speed control by pressing the SET ACCEL switch.
n Press the brake or clutch pedal slightly. The speed control is suspended, but you can reset it by pressing SET ACCEL or return to the previous set speed with the RSM switch.
In addition, the speed control is turned off each time you turn
the vehicle ignition off.
Driving uphill or on a steep grade
When the speed control is on, your vehicle may significantly drop speed when driving uphill, especially with a heavy load. If the speed drops more than 8 to 14 mph (15 - 25 km/h) the automatic speed control will, by design, be canceled. You may have to temporarily resume manual speed control while driving up a steep grade in order to maintain the speed you desire.
If the speed control “dropped out” after your climb is completed, the speed of your light truck can be reset with the SET ACCEL switch, or returned to the previous set speed with the RSM switch, as long as you are driving over 30 mph (50 km/h).
Cancelling and Resuming a Set Speed
If you press the brake pedal, the speed control is cancelled. You can return to the speed you set by using the RSM switch, as long as you did not press the OFF switch.
To resume the speed you had before, you must be driving at least 30 mph (50 km/h).
Press and release the RSM switch. Your vehicle gradually returns to the previously set speed and then maintains it.
Speed Control Indicator (If equipped)
A SPEED CONTROL light is displayed in the instrument cluster when the speed control system is engaged. The display will turn off when the brake pedal is pressed or if speed control is shut off.
This display does not indicate any problems with the speed control, but is simply a convenient way of knowing when it is active.
Акулыч, закрывай это все нафиг, а то мы счаз договоримся до того что начнем выяснять в какую сторону откручивать гайки с левой резьбой
