какой номер ошибки через сканер
Да будет В2296. Но он менее информативен, т.к. указывает на несколько причин.
Scanner \ Flash
B1231 13 Longitudinal Acceleration Threshold Exceeded (Crash Data Memory Full)
B1317 Battery Voltage or VSS (12 volts) High
B1318 Battery Voltage or VSS (12 volts) Low
B1342 12 RCM is Faulted
B1869 Airbag (SRS) Indicator Inoperative
B1870 Airbag (SRS) Warning Indicator Circuit Short Circuit to Battery
B1884 18 PAD Warning Lamp Circuit Failure
B1890 18 PAD Warning Lamp Circuit Short Circuit To Battery
B1891 53 Airbag (SRS) Tone Warning Indicator Circuit Short Circuited to Battery Or Ignition
B1892 53 Airbag (SRS) Tone Warning Indicator Circuit Short Circuited To Ground or Earth Or Open Circuit
B1916 15 Driver Airbag (SRS) Circuit Short Circuited To Battery Or Ignition
B2290 16 Occupant Classification System Fault
B2292 33 Restraint System Safety Belt Pretensioner Status (Driver Pretensioner Circuit Failure)
B2292 34 Restraint System Safety Belt Pretensioner Status (Passenger Pretensioner Circuit Failure)
B2293 19 Restraint System Airbag (SRS) Status (Driver Front Airbag (SRS) Circuit Failure)
B2293 21 Restraint System Airbag (SRS) Status (Passenger Front Airbag (SRS) Circuit Failure)
B2295 22 Restraint System Side Airbag (SRS) Status (Driver Seat Side Airbag (SRS) Circuit Failure)
B2295 23 Restraint System Side Airbag (SRS) Status (Passenger Seat Side Airbag (SRS) Circuit Failure)
B2296 42 Restraint System Crash or Impact Sensor Status (Front Impact Severity Sensor Circuit Failure)
B2296 43 Restraint System Crash or Impact Sensor Status (Driver Side Crash or Impact Sensor Circuit Failure)
B2296 44 Restraint System Crash or Impact Sensor Status (Passenger Side Crash or Impact Sensor Circuit Failure)
B2434 51 Driver Safety Belt Buckle Switch Circuit Short Circuit to Ground or Earth
B2435 51 Driver Safety Belt Buckle Switch Resistance Out of Range
B2438 52 Passenger Safety Belt Buckle Switch Circuit Short Circuit to Ground or Earth
B2439 52 Passenger Safety Belt Buckle Switch Resistance Out of Range
B2477 Module Configuration Failure
B2691 51 Driver Safety Belt Buckle Switch Circuit Fault
B2692 52 Passenger Safety Belt Buckle Switch Circuit Fault
B2909 16 Belt Tension Sensor Fault
