Часто пользуюсь Rockauto.com как справочником:
1994 FORD EXPLORER 4.0L V6 : Drivetrain : Universal Joint
Price
SKF Part # 10153
4 WHEEL/ALL WHEEL DRIVE,FRONT SHAFT FRONT JOINT - BEARING STRAP KIT: 1-0022 w/1/4-28 BOLTS OR 1-0024 w/5/16-24 BOLTS - U-BOLT KIT: 1-0089 - SILVER
Except AUTO TRANS and Except 4 WHEEL/ALL WHEEL DRIVE,REAR SHAFT ALL JOINTS - BEARING STRAP KIT: 1-0022 w/1/4-28 BOLTS OR 1-0024 w/5/16-24 BOLTS - U-BOLT KIT: 1-0089 - SILVER
w/AUTO TRANS,REAR SHAFT ALL JOINTS - BEARING STRAP KIT: 1-0022 w/1/4-28 BOLTS OR 1-0024 w/5/16-24 BOLTS - U-BOLT KIT: 1-0089 - SILVER [Wholesaler Closeout -- 30 Day Warranty] (Only 10 Remaining)
$3.35
ROCKFORD CONSTANT VELOCITY Part # K456
WHL JOINTS - 1.063" OD BRG,4 WHEEL/ALL WHEEL DRIVE [Wholesaler Closeout -- 30 Day Warranty] (Only 11 Remaining)
$5.80
ACDELCO Part # 45U0107 {#45U0150, 89029289, 89029332} Professional
Rear Driveshaft at Rear Axle; 4WD; w/1-1/16" O.D. Bearings
At Transmission; RWD; w/1-1/16" O.D. Bearings
At Rear Axle; RWD; w/1-1/16" O.D. Bearings
Front Driveshaft - CV at Transfer Case; 4WD; w/1-1/16" O.D. Bearings
Front Driveshaft at Front Axle; 4WD; w/1-1/16" O.D. Bearings
Rear Driveshaft at Transmission; 4WD; w/1-1/16" O.D. Bearings
Part Image
$7.72
MOOG/PRECISION Part # 369 Premium; 1.063 Cap Diameter, 3.218 Outside to Outside the Cap. One of our most popular parts
Part Image
$7.76
FEDERATED Part # 436
Front Axle Shaft - Right Outer; 4WD; Non-Greaseable Super-Strength; w/1-1/16" O.D. Bearings; Non-Greaseable Super Strength (Only 5 Remaining)
$8.66
MOOG/PRECISION Part # 354 Premium One of our most popular parts
Rear Driveshaft at Rear Axle; 4WD; 4 door; Standard trans.; w/1-1/16" O.D. Bearings
Rear Driveshaft at Transmission; 4WD; 4 door; Standard trans.; w/1-1/16" O.D. Bearings
Part Image
$9.13
SKF Part # 10297
4 WHEEL/ALL WHEEL DRIVE,FRONT WHEELS ALL JOINTS - w/1.188" BEARING CUP DIAMETER - SILVER [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$9.16
ACDELCO Part # 45U0106 {#89029288} Professional; 1 1/16" Cap
Part Image
$9.23
TRW Part # 20435
AXLE SHAFT,4 WHEEL/ALL WHEEL DRIVE,w/1.063" BEARING CAPS [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 1 Remaining)
$9.35
ROCKFORD CONSTANT VELOCITY Part # K456HD
WHL JOINTS - 1.063" OD BRG,4 WHEEL/ALL WHEEL DRIVE [Wholesaler Closeout -- 30 Day Warranty] (Only 6 Remaining)
$9.39
DANA HOLDING CORP Part # 5153X Spicer
Front Shaft Rear Joint; 4WD; Diagram Location: 2,3,4; Diagram: I
Front Shaft Center Joint; 4WD; Diagram Location: 2,3,4; Diagram: I
Front Shaft Front Joint; 4WD; Diagram Location: 2,3,4; Diagram: I
Rear Shaft Front and Rear Joints; RWD; Diagram Location: 1,2; Diagram: A; Lube fitting in body
Rear Shaft Front and Rear Joints; 4WD; 2 door; Standard trans.; Diagram Location: 5,6; Diagram: I
Part Image
$9.49
SKF Part # 10297BF
4 WHEEL/ALL WHEEL DRIVE,FRONT WHEELS ALL JOINTS - w/1.188" BEARING CUP DIAMETER - STANDARD [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 7 Remaining)
$9.89
O'REILLY/MASTER PRO Part # P436
4 WHEEL/ALL WHEEL DRIVE,4ISR & 4OSR> 1.063" BRG OD - WHEEL JOINTS - EDDIE BAUER, LIMITED, XL, XLT [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty]
$10.48
ACDELCO Part # 45U0145 {#89029327} Professional; NON-GREASABLE U-JOINT
At Transmission; RWD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Front Driveshaft at Front Axle; 4WD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Rear Driveshaft at Rear Axle; 4WD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Rear Driveshaft at Transmission; 4WD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Front Driveshaft - CV at Transfer Case; 4WD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
at Rear Axle; RWD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Part Image
$10.83
MOOG/PRECISION Part # 269 Non-Greasable Super Strength One of our most popular parts
Part Image
$11.39
NEAPCO Part # 20456
4 WHEEL/ALL WHEEL DRIVE,FRONT WHEELS ALL JOINTS - w/1.063" BEARING CUP DIA. - STD [Wholesaler Closeout -- 30 Day Warranty]
$11.91
MOOG/PRECISION Part # 254 Non-Greasable Super Strength One of our most popular parts
Part Image
$12.01
ACDELCO Part # 45U0111 {#89029293} Professional; GREASABLE U-JOINT
Rear Driveshaft at Transmission; 4WD; w/1-1/16" O.D. Bearings; Greasable Super Strength
at Rear Axle; RWD; w/1-1/16" O.D. Bearings; Greasable Super Strength
Front Driveshaft at Front Axle; 4WD; w/1-1/16" O.D. Bearings; Greasable Super Strength
At Transmission; RWD; w/1-1/16" O.D. Bearings; Greasable Super Strength
Rear Driveshaft at Rear Axle; 4WD; w/1-1/16" O.D. Bearings; Greasable Super Strength
Front Driveshaft - CV at Transfer Case; 4WD; w/1-1/16" O.D. Bearings; Greasable Super Strength
Part Image
$12.30
SKF Part # 10298
4 WHEEL/ALL WHEEL DRIVE,FRONT WHEELS ALL JOINTS - STD - w/1.188" BEARING CUP DIA [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$12.43
MOOG/PRECISION Part # 280 Greasable Super Strength One of our most popular parts
Part Image
$12.54
SKF Part # 20456
4 WHEEL/ALL WHEEL DRIVE,FRONT WHEELS ALL JOINTS - w/1.063" BEARING CUP DIAMETER - SILVER [Wholesaler Closeout -- 30 Day Warranty] (Only 2 Remaining)
$12.64
ACDELCO Part # 45U0141 {#89029323} Professional; NON-GREASABLE U-JOINT
Rear Driveshaft at Rear Axle; 4WD; 4 door; Standard trans.; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Rear Driveshaft at Transmission; 4WD; 4 door; Standard trans.; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Part Image
$12.69
NEAPCO Part # 20456BF
4 WHEEL/ALL WHEEL DRIVE,PREMIUM - FRONT WHL JOINTS ALL POSITIONS w/1.063" BEARING CUPS [Wholesaler Closeout -- 30 Day Warranty] (Only 4 Remaining)
$12.95
ACDELCO Part # 45U0122 {#89029304} Professional; NON-GREASABLE U-JOINT
Front Axle Shaft - Left Outer; 4WD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Front Axle Shaft - Right Outer; 4WD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Front Axle Shaft - Right Inner; 4WD; w/1-1/16" O.D. Bearings; Non-Greasable Super Strength
Part Image
$13.43
MOOG/PRECISION Part # 270 Greasable Super Strength One of our most popular parts
Part Image
$13.67
SKF Part # 20456BF
4 WHEEL/ALL WHEEL DRIVE,FRONT WHEELS ALL JOINTS - w/1.063" BEARING CUP DIAMETER - STANDARD [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 8 Remaining)
$13.74
ACDELCO Part # 45U0104 {#89029286} Professional; NON-GREASABLE U-JOINT
Front Axle Shaft - Right Outer; 4WD; w/1-3/16" O.D. Bearings; Non-Greasable Super Strength
Front Axle Shaft - Right Inner; 4WD; w/1-3/16" O.D. Bearings; Non-Greasable Super Strength
Front Axle Shaft - Left Outer; 4WD; w/1-3/16" O.D. Bearings; Non-Greasable Super Strength
Part Image
$13.91
ACDELCO Part # 45U0183 {#89029365} Professional; GREASABLE U-JOINT
Front Axle Shaft - Right Inner; 4WD; w/1-1/16" O.D. Bearings; Greasable Super Strength
Front Axle Shaft - Right Outer; 4WD; w/1-1/16" O.D. Bearings; Greasable Super Strength
Front Axle Shaft - Left Outer; 4WD; w/1-1/16" O.D. Bearings; Greasable Super Strength
Part Image
$14.32
ACDELCO Part # 45U0115 {#89029297} Professional; GREASABLE U-JOINT
Rear Driveshaft at Rear Axle; 4WD; 4 door; Standard trans.; w/1-1/16" O.D. Bearings; Greasable Super Strength
Rear Driveshaft at Transmission; 4WD; 4 door; Standard trans.; w/1-1/16" O.D. Bearings; Greasable Super Strength
Part Image
$14.35
MOOG/PRECISION Part # 371 Non-Greasable Super Strength One of our most popular parts
Part Image
$14.55
DANA HOLDING CORP Part # 5213X Spicer
Rear Shaft Front and Rear Joints; 4WD; 4 door; Standard trans.; Diagram Location: 5,6; Diagram: I
Part Image
$14.74
MOOG/PRECISION Part # 436 Non-Greasable Super Strength
Part Image
$15.23
MOOG/PRECISION Part # 377 Greasable Super Strength One of our most popular parts
Part Image
$15.79
ACDELCO Part # 45U0114 {#89029296} Professional; GREASABLE U-JOINT
Front Axle Shaft - Right Outer; 4WD; w/1-3/16" O.D. Bearings; Greasable Super Strength
Front Axle Shaft - Right Inner; 4WD; w/1-3/16" O.D. Bearings; Greasable Super Strength
Front Axle Shaft - Left Outer; 4WD; w/1-3/16" O.D. Bearings; Greasable Super Strength
Part Image
$16.31
MOOG/PRECISION Part # 466 Greasable Super Strength
Part Image
$16.70
FEDERATED Part # 377
Front Axle Shaft - Right Outer; 4WD; Non-Greaseable Super-Strength; w/1-3/16" O.D. Bearings; Greaseable Super Strength (Only 19 Remaining)
$17.18
DANA HOLDING CORP Part # 5760X Spicer
Front Axle at Wheels; 4WD; Dana Model 35 Axle; Diagram Location: 1; Diagram: I
