Диагностика ELM327
820
Выложи еще сами ПИДы. Сейчас многие программы имеют возможность добавления пользовательских ПИДов.
ereminds
Ford Explorer 1999
Да собственно ни как не соберусь все собрать во едино, все на огрызках бумажек.
Ford PID List
Acronym PID # Description Ford Units
4X4L 1101 b2 Requested 4 Wheel Drive Input ON/OFF
ACCS 1101 b0 Air Conditioning Cycling Switch Input ON/OFF
ACP 1102 b0 A/C Head Pressure Switch Input OPEN/CLOSED
ACP V 1638 A/C Head Pressure Switch Input VOLTS
AIR 1104 b4 Secondary AIR Pump Control ON/OFF
AIRM 110C b1 Secondary AIR Pump Monitor ON/OFF
BARO 1127 Barometric Pressure (may be software determined) Hz
BPP/BOO 1101 b1 Brake Pedal Position/Brake On-Off Switch Input ON/OFF
CAMDCR 16CF Commanded Duty Cycle for VCT Solenoid %
CAMERRR 16CE VCT Error in Crankshaft Degrees DEGREES
CAS GND 16CO PCM Case Ground VOLTS
CCS 1105 b7 Coast Clutch Solenoid Control ON/OFF
CHT 1624 Cylinder Head Temperature Input DEGREES
CHT V 1685 Cylinder Head Temperature Input VOLTS
CPP/PNP 1101 b3 Clutch Pedal/Park Neutral Position Switch Input ON/OFF
DPFEGR 114E Differential Pressure Feedback EGR Input VOLTS
ECT 1139 Engine Coolant Temperature Input DEGREES
ECT V 114D Engine Coolant Temperature Input VOLTS
EFTA 168E Engine Fuel Temperature - Bank 1 Input DEGREES
EFTA V 168D Engine Fuel Temperature - Bank 1 Input VOLTS
EFTB 169O Engine Fuel Temperature - Bank 2 Input DEGREES
EFTB V 168F Engine Fuel Temperature - Bank 2 Input VOLTS
EGRVR 113C EGR Valve Vacuum Control %
EOT 1310 Engine Oil Temperature Sensor Input DEGREES
EOT V 16AF Engine Oil Temperature Sensor Input VOLTS
EOTF 16A9 Engine Oil Temperature Fault Detection YES/NO
EPC 11C0 Transmission Line Pressure Control PSI
EPC V 11B2 Transmission Line Pressure Control VOLTS
EVAPCPF 162F b2 Evaporative Emissions Canister Purge Fault YES/NO
EVAPCV 1167 Evaporative Emissions Canister Purge Vent Control %
EVAPCVF 1630 b3 Evaporative Emissions Canister Purge Vent Fault YES/NO
EVAPPDC 1166 Evaporative Emissions Canister Purge Control %
EVAPPF 1627 Evaporative Purge Flow Input VOLTS
EVAPVMA 1636 Evaporative Vapor Management Valve Internal Circuit
Monitor VOLTS
FF 16AB Flex Fuel Sensor Input %
FLI 16C1 Fuel Level Indicator Input %
FLI V 16BF Fuel Level Indicator Input VOLTS
FP M 1673 Fuel Pump Secondary Monitor %
FPF 162E b6 Fuel Pump Output Fault YES/NO
FPM 110C b0 Fuel Pump Secondary Monitor ON/OFF
FRP 168C Engine Injector Pressure Input PSI
FRP V 168B Engine Injector Pressure Input VOLTS
FSVF 1691 b1 Engine Fuel Solenoid Valve Fault YES/NO
FSVM 1691 b2 Engine Fuel Solenoid Valve Secondary Monitor ON/OFF
FTP 1687 Fuel Tank Pressure Input in.H2O
FTP V 1639 Fuel Tank Pressure Input VOLTS
FUELPW1 1141 Injector Pulse Width Bank 1 MILLISECONDS
FUELPW2 1142 Injector Pulse Width Bank 2 MILLISECONDS
GEAR 11B3 Transmission Gear Status GEAR
GENF 0927 b2 Generator Output Fault Detection YES/NO
GENFDC 16E8 Generator Field Control Output %
GFS 0939 Generator Field Signal Monitor %
HFC 1103 b3 High Speed Fan Control ON/OFF
HFCF 162F b1 High Speed Fan Control Fault YES/NO
HTR11 1631 b0 Bank 1 Upstream O2S Heater Control ON/OFF
HTR11F 1631 b4 Bank 1 Upstream O2S Heater Circuit Fault ON/OFF
HTR12 1631 b1 Bank 1 Downstream O2S Heater Control ON/OFF
HTR12F 1631 b5 Bank 1 Downstream O2S Heater Circuit Fault ON/OFF
HTR21 1631 b2 Bank 2 Upstream O2S Heater Control ON/OFF
HTR21F 1631 b6 Bank 1 Downstream O2S Heater Circuit Fault ON/OFF
HTR22 1631 b3 Bank 2 Downstream O2S Heater Control ON/OFF
HTR22F 1631 b7 Bank 1 Downstream O2S Heater Circuit Fault ON/OFF
HTRX1 1102 b1/6 O2S Upstream Heater Control ON/OFF
HTRX2 1102 b2/7 O2S Downstream Heater Control ON/OFF
IAC 1153 Idle Air Control %
IAT 1123 Intake Air Temperature Input DEGREES
IAT V 114A Intake Air Temperature Input VOLTS
IAT2 16A8 Intake Air Temperature Sensor 2 Input DEGREES
IAT2 V 16A7 Intake Air Temperature Sensor 2 Input VOLTS
IMRC 1103 b4 Intake Manifold Runner Control ON/OFF
IMRC F 162F b6 Intake Manifold Runner Control Fault YES/NO
IMRCM 1634 Intake Manifold Runner Control Monitor Input Bank 1 VOLTS
IMTV 1684 Intake Manifold Tuning Valve Control %
IMTVF 162F b5 Intake Manifold Tuning Valve Fault YES/NO
INJ1F-8F 162D b0-7 Fuel Injector Primary Fault YES/NO
INJ9F-10F 16EA b0-1 Fuel Injector Primary Fault YES/NO
KS1 V 16E6 Knock Sensor Input Bank 1 VOLTS
KS2 V 16E7 Knock Sensor Input Bank 2 VOLTS
LFC 1103 b2 Low Speed Fan Control ON/OFF
LFCF 162F b0 Low Speed Fan Control Fault YES/NO
LONGFT1 1156 Long Term Fuel Trim Bank 1 %
LONGFT2 1157 Long Term Fuel Trim Bank 2 %
MAF 1671 Mass Airflow Rate Input GM/S
MAF V 1177 Mass Airflow Rate Input VOLTS
MAF V 1633 Mass Airflow Rate Input VOLTS
MIL 1103 b5 Malfunction Indicator Lamp Control ON/OFF
MPLRNa 16DD b0 Misfire Wheel Profile Learned in KAM YES/NO
OCTADJ 1102 b3 Octane Adjust Status OPEN/CLOSED
OCTADJS 16EF b0 Octane Adjust Software Status RETARD/NO RETARD
O2S11 1173 Bank 1 Upstream O2S Input VOLTS
O2S12 1174 Bank 1 Downstream O2S Input VOLTS
O2S21 1175 Bank 2 Upstream O2S Input VOLTS
O2S22 1176 Bank 2 Downstream O2S Input VOLTS
PIP 1102 b4 Profile Ignition Pickup Input ON/OFF
PSP 1101 b7 Power Steering Pressure Switch Input HIGH/LOW
PSP V 1626 Power Steering Pressure Input VOLTS
PSP V 1625 Power Steering Pressure Input VOLTS
PTO 160D b5 Power Take Off Status Input ON/OFF
RCAM 16CD VCT Solenoid Commanded in Crank Shaft Degrees DEGREES
REV 1697 b0 Transmission Reverse Switch Input ON/OFF
RPM 1165 Engine Speed Based Upon CKP Input RPM
SCB 0964 b0 Supercharger Bypass Control ON/OFF
SCBF 0964 b1 Supercharger Bypass Control Fault YES/NO
SCICP 0964 b2 Supercharger Intercooler Pump Control ON/OFF
SCICPF 0964 b3 Supercharger Intercooler Pump Control Fault YES/NO
SS1 1105 b4 Shift Solenoid 1 Control ON/OFF
SS2 1105 b5 Shift Solenoid 2 Control ON/OFF
SS3 1105 b6 Shift Solenoid 3 Control ON/OFF
TCC 11B0 Torque Converter Clutch Control %
TCCA 110E b7 Torque Converter Clutch Control Internal Circuit Monitor
ON/OFF
TCIL 1104 b2 Transmission Control Indicator Lamp Clutch Control Status
ON/OFF
TCS 1101 b4 Transmission Clutch Convertor Control Switch Input ON/OFF
TFT 1674 Transmission Fluid Temperature Input DEGREES
TFT V 11BD Transmission Fluid Temperature Input VOLTS
TP MODE 1125 Throttle Position Mode C/T, P/T, WOT
TP V 1154 Throttle Position Input VOLTS
TPB 1629 Secondary Throttle Position Input VOLTS
TPREL 1169 Lowest Steady TP Voltage Since Engine Start (RATCH) VOLTS
TR 11B6 Transmission Selector Position Input Status POSITION
TR V 1151 Transmission Selector Position Input Status VOLTS
TR D 16B5 Transmission Selector Position Input Status (Digital) BINARY
TSS/ISS 11B4 Turbine Shaft Speed/Input Shaft Speed RPM
VCTA 16B1 b6 VCT Control Circuit Monitor ON/OFF
VCTENA 16B1 b5 Conditions Correct to Enable VCT YES/NO
VPWR 1172 Vehicle Power Voltage VOLTS
VREF 1155 Vehicle Reference Voltage VOLTS
WAC 1104 b0 A/C Clutch Command ON/OFF
WACF 162E b5 WOT A/C Primary Circuit Fault YES/NO
10 - PCM
20 - пневма
28 - АБС
48 - Сигналка
52 - ГЕМ
58 - Айрбэг
98 - Климат
С0 - Иммо
А вот сканеры пидов для PWM
и для ISO
где модуль набираешь адрес модуля, 10 для мотора
где пид набираешь первые 2 цифры пида. Самые важные начинаются на на 11 и на 16.
В итоге всех прог получится файл, там все что нашлось.
Тотальный перебор длятся около 10 часов.
  • 13.1 КБ Просмотры: 140
820
Те, что в приложенном текстовом файле у меня читает Torque Pro. Хотелось бы чего то по пневме вытащить, по по гему, климату...
ereminds
Ford Explorer 1999
По пневме и гему 000D - скорость. D102 - напруга. 3975 - датчики уровня. Но по этим модулям производитель делал что хочется. В тарасовском геме совсем другие пиды чем в эксповском.
Пройдись сканером, пришли файлы, что знаю подскажу. смотри А1, А4, С1, С8, С9, 00, 01, 02, 13, 21, 29, 39, 49, 59, 61, Е2. У тебя должен быть еще модуль ВАПС.
820
У меня шнурок синезубый, а сканер просит ком порт.
ereminds
Ford Explorer 1999
У меня такой же. Не помню, сто лет назад мучился, в диспетчере устройств вроде написано что у меня блютуз это СОМ5, я так к этому порту и цепляюсь. И с другими прогами так же.
Добавлено через 7 минут
И ты не тот сканер скачал, пневма и гем на k-line ISO9141 висят.
820
Ты бы приехал на встречу клубную, там бы и поэкспериментировали на разных машинах.
Unsend
Ford Explorer 2008 LTD
Moscow
По поводу блютулзовых обд сканеров - при включении блютулз появляется новый комп порт - на него и надо сканер вешать - можно посмотреть в устройствах>ком порты. А мона и перебрать все - на каком-нить заработает. Народ вопрос в другом - какой голубозубый убд сканер посоветуете на Эдди бауэр 4.6 2008 - кто что пробовал? Просто не охота пачками перебирать чтобы найти 100% рабочий - может у кого опыт есть?
Зы - по поводу андроида видел на апсторе гугловом был Torque lite - у меня знакомый говорил что работала софтина супер, но своего опыта общения с ней не имел. Мона будет попробовать как сканер куплю - на крайняк из нее конфиги под протоколы содрать мона - если надо будет помочь - свистите:)
Добавлено через 9 минут
ЗЫЗЫ кстати - встреча клуба 28 сентября;) Я бы тож в очередь встал подопытных:))))
amur
56
EXPLORER 3
V
Torque именно этим и балуется"КУПИИ мой адапьер"
YoDo
30
Ford Expedition 2005
Екатеринбург
Доброго времени суток!
Вчера методом научного тыка подключил ELM327 Bluetooth адаптер (версия 1.5) к своему Ford Explorer 1994 года.
Поставил на телефон Torque.
Программа соединилась с адаптером, подключилась к бортовому компьютеру и оооочень задумалась с сообщением "Поиск автомобиля".
Подскажите что дальше (может кто-то уже справился с подключением к "не OBD-II" фордам)?
Журнал Torque найти не смог.
