Но заливная горловина одна.
На моём первом траке было два бака и две горловины.
и другая версия расшифровки вина:
Features
******************** MAJOR ATTRIBUTES ********************
Series: F350SD
Series: 7.3 L
VIN Decode Information
MANUFACTURER: FORD MOTOR COMPANY, USA
MAKE: FORD
SERIES: F350SD
TYPE: TRUCK (COMPLETE VEHICLE)
ENGINE MAKE: NAVISTAR
ENGINE: 7.3
CYLINDERS: 8
ENGINE TYPE: OHV, TURBO, NAVISTAR
FUEL TYPE: DIESEL
NET BRAKE HP: 215-235
CHASSIS TYPE: 4X2
BODY STYLE: PICKUP-CREW CAB - DRW
GVWR CLASS: CLASS 3
GVWR RANGE: 10,001 - 14,000 POUNDS
BRAKES: HYDRAULIC
PLANT: KENTUCKY TRUCK: LOUISVILLE, KENTUCKY
VCIS/TSL/VBOM
******************** VCIS INFORMATION ********************
VEHICLE DESCRIPTION: F350 CREW CAB PICKUP 4X2
VEHICLE TYPE: W32
PAINT CODE: FN
TRIM CODE: 32
RPO WHEEL VO CODE: 172
GROSS VEHICLE WEIGHT: 11000
AXLE REAR (RWD): D796C
BUMPER (FRONT): 1C3417750GHYBCC
VCIS/TSL/VBOM
BUMPER (REAR): YC3517775DBSMAW
CHARGE ALTERNATOR: F81U10300EB
COOLANT RADIATOR ID: YC3H8005BA
COOLANT HOSE UPPER ID: YC358B274CC
COOLANT HOSE LOWER ID: YC358B273CF
SPEC. ORDER CD: 71
SHAFT REAR ID: F81A4K145AVC
EMISSION CALIBER NO.: 1F719N0
EMISSION PROCESS ID: 1C3F12A650ABC
ENGINE TAG ID: TE002AA
FUEL TANK ID: 1C349K007MA
GRILL: 1C348200BAYBAC
INSTRUMENT CLUSTER ID: XC3F10849CE
MIRROR OUT: 1C3417683ABYGAK 1C3417682ABYGAK
STEERING ASSEMBLY: YL3C3C529AA
STEERING PITMAN: YC353590DB
SUSPENSION SPRING ID (FRONT): F81A5310UA
SUSPENSION SPRING ID (REAR): 1C345560DB
TRANSMISSION ID: 1C3P7000EB
WHEEL COVER ID: 1C341A108GA
WHEEL COVER SPARE: F81A1015CA
WHEEL COVER ROAD: F81A1015CA
WIRING 1: 1C3T14401EAE
WIRING 2: YC3T14405BAD
WIRING 3: 1C3T15525CB
WIRING 4: 1C3T12A581KAG
WIRING 5: 1C3T13A409BC
WIRING 6: YC3T13A576CA
WIRING 7: 1C3T14A005RAG
******************** VCIS MINOR FEATURES ********************
CAB BACK PNL LESS STOWAGE COMP
TAILGATE EDGE GUARD
VCIS/TSL/VBOM
WITH TAILGATE LOCK
WITH 8' STYLESIDE BOX-STEEL
STAKE POCKET TIE DOWN HOOKS
WITH LOAD BOX EDGE PROTECTORS
172"/4369MM WHEELBASE
XLT
(-) VERSION PACKAGES
LESS SPECIAL PURPOSE VEHICLE
LESS FLEET RELATED ITEMS
KENTUCKY TRUCK PLANT BUILD
U.S. SALES
WITH CAMPER PACK
COMPLETE VEHICLE
11,000 LB. GVW
LESS APPEARANCE GROUP
WITH COLD WEATHER GROUP # 1
LESS EXTERIOR APPEARANCE PACK
WITH POWER EQUIPMENT GROUP
LESS AMBIENT TEMP/SPEED PACK
WITH ON-BOARD DIAGNOSTIC SYSTEM
KENTUCKY TRUCK PLANT BUILD ONLY
WITH ENGLISH LANGUAGE LABEL
OWNER HAND BOOK PACK
WITH 2 TON MECHANICAL JACK
LESS WARNING DISPLAY
LESS FIRE EXTINGUISHER
LESS TOOL KIT
LESS FIRST AID KIT
WITH POWER FRONT WINDOWS
WITH ELECTRIC REAR WINDOWS
WITH TINTED GLASS ALL ROUND
WITH SLIDING REAR WINDOW
LESS OVERHEAD CONSOLE
LESS FLOOR MOUNTED CONSOLE
FIXED FOOT PEDALS
WITH CARPET FLOOR COVERING
LESS I/P INSERT
SUNVISOR - SINGLE DRIVER W/STRAP
WITH SUNVISOR MIRROR - PASSENGER
WITH LEVEL 3 DOOR TRIM PANEL
WITH SOUND INSULATION PACK LEVEL 1
LESS EXTERIOR SUN VISOR
WITH BRIGHT FRONT GRILLE
LESS LOWER BODY MOULDING
LESS REAR WINDOW PROTECTOR
LESS SIDE AUXILIARY STEP
WITH DIPPING REAR VIEW MIRROR
DUAL SAIL MTD POWER MIRRORS
LESS TEMP CONTROL DRIVER SEAT
LESS TEMP CONTROL PASSENGERS SEAT
WITH SEAT BELT WARNING LIGHT
WITH 2ND ROW BENCH SEAT - 3 PASSNGR
WITH DRIVER 2 WAY MNL. SEAT ADJUST
TRAILER TOW PREP PACK
WITH TRAILER TOWING ATTACHMENTS
WITH FRONT TOWING HOOK
EXTERIOR DOOR HANDLE - BLACK
WITH CENTRAL LOCKING SYSTEM
LESS DOOR ENTRY REMOTE CONTROL UNIT
LESS BODY TU-TONE PAINT
LESS BODYSIDE ACCENT STRIPE
FRONT BUMPER - STEEL CHROMED
REAR BUMPER - STEEL STEP - CHROMED
WITH FRONT LICENCE PLATE BRACKET
WITH INERTIA FRONT SEAT BELT
WITH DRIVER AIR BAG
WITH PASSENGER AIR BAG
ADJUSTABLE'D'RING-DRIVERS SEAT BELT
LESS PASSENGER AIR BAG DEACTIVATION
WITH FRAME MOUNTED TYRE CARRIER
WITH STEEL SPARE WHEEL
WITH DOUBLE REAR WHEELS
6 X 16" FORGED ALLOY WHEEL
LT235/85R-16E BSW A-S TYRES
WITH CONVENTIONAL SPARE TYRE
LESS WHEEL COVERS
LESS HUB COVERS
IMMERSION HEATER ENGINE
LESS ATTITUDE/RIDE HEIGHT PACK
WITH STANDARD DUTY FRONT SUSPENSION
4700 LB. FRONT AXLE
WITH FRONT STABILIZER BAR
WITH HEAVY DUTY REAR SPRINGS
WITH REAR STABLIZER BAR
REAR AXLE LIMITED SLIP DIFFERENTIAL
WITH DANA AXLE
LESS DECAL - PICKUP BOX
8250 LB(3742 KG) REAR AXLE ASY
WITH TWIN I BEAM FRONT AXLE
LESS CATALYST
WITH 4 WHEEL DISC-BRAKE
4 WHEEL ANTI-LOCK BRAKING SYSTEM
WITH STANDARD TRANSMISSN OIL COOLER
LESS TRANSMISSION POWER TAKE OFF
LESS TRANSFER CASE
LESS SKID PLATES
SEATS - INDIVIDUAL 40/20/40
WITH MID-SHIP FUEL TANK
LESS AUXILIARY FUEL TANK
LESS FU TNK PORT EXTEN TUBE
WITH NON LOCKING FUEL CAP
FOR UNLEADED FUEL
LESS GASEOUS PREP PACK
WITH LOW SULFUR DIESEL FUEL CONTENT
LESS REMOTE ENGINE CONTROL
LESS STEERING DAMPER
WITH TILT STEERING WHEEL
BASIC TYPE STEERING WHEEL
WITH SPEED CONTROL
WITH MPH/KMH SPEEDOMETER
LESS REVERSE PROXIMITY SENSOR
LESS ENGINE IMMOBILISER
HEAVY DUTY BATTERY
HEAVY DUTY ALTERNATOR
ELECT PREM STRO/CASS/DISC/CLOCK
LESS RADIO PRE-EQUIPMENT PACK
WITH NAAO RADIO FREQUENCY
LESS DAYTIME RUNNING LAMPS
WITH AERO HEADLAMPS
LESS FRONT FOG LAMPS
PARKING LAMP LENSE-AMBER
ROOF MARKER/CLEARANCE LIGHTS-CONV
ENGINE COMPARTMENT LIGHT
WITH DUAL BEAM DOME MAP LIGHT
WITH GLOVE BOX ILLUMINATION
WITH LOAD COMPARTMENT LAMP
TAIL LAMPS - LEVEL 1
LESS HIGH MOUNTED STOP LAMP
NO DESCRIPTION [MD0F0]
F81A 5310 UA LEFT FRONT COIL SPRING
F81A 5310 UA RIGHT FRONT COIL
LESS B&A CONTROL CODES ISSUE 030388
******************** IDENTIFICATION CODES ********************
RADIATOR: YC3H8005BA
CALIBRATION CODE: 1F719N0
STEERING GEAR: YL3C3C529AA
TRANSMISSION: 1C3P7000EB
INSTRUMENT CLUSTER: XC3F10849CE
REAR AXLE: D796C
WHEEL ASSY: YC353590DB
WHEEL COVER: YL3C3C529AA
