Нужны распиновки разъёмов на Ford Bronco 2
SPARTACUS
Ford Transit
Щёкино
Очень нужны распиновки ЭБУ и большого разъёма в моторном щите.
Нужно привести проводку в порядок.
Машина 1989 г.
Любитель Фордов
146
Ford Explorer 94
Машина 1989 г.
для таких работ надо скачивать прогу на авто типа митчела или оллдата.
распиновкой разъёмов это обычно не заканчивается, а тока начинается.
дядя Алик
Бронконекромант
654
Ford Bronco 1984
Электросталь
BWP (Big White Plug) pinouts - Referring to the 1994 Explorer wiring guide *picture* above.
(sorry for the formatting, can't figure out how to make columns)
Wire# Color Circuit
1 Red-White Temp Gauge to Temp Sending unit
2 Yellow-White Fuel Gauge to Fuel Gauge sender
3 White-Lt Blue Front Right Turn signal
4 Tan-Lt Green Anti Theft System switch feed
5 Lt Green-White Front Left Turn signal
6 Red Windshield Wiper Switch to Windshield Wiper motor
7 Purple-Orange Fused Run Only feed
8 Lt green Stoplamp switch to stoplamps
9 Dk Green-Lt Grn Shift on the fly 4x4
10 Pink-Lt Green EEC Module to Check Engine Lamp
11 not used
12 Tan-Yellow Ignition Coil negative terminal
13 Tan-Lt green Brake fluid switch to reservoir module
14 Gray-Red sensor signal return
15 not used
16 Black-White washer pump motor feed
17 purple-white dual brake switch indicator lamp
18 lt blue-orange O2 sensor feed - running only
19 not used
20 black-pink Windshield wiper switch to windshield wiper motor
21 dk blue-orange Windshield wiper switch to windshield wiper motor
22 white windshiled wiper switch to windshield wiper motor
23 tan-orange fog lamp switch to fog lamp
24 lt blue-black fog lamp switch to fog lamp relay
25 dark green failure warning light
26 lt blue-pink ABS control module feed
27 lt gray-orange Battery saver lamp feed
28 not used
29 not used
30 pink crank enable relay
31 white-red oil pressure indicator to oil press sending unit
32 light pink oil level relay to oil level sensor
33 not used
34 red-white electric t-case to manual level position sensor
35 lt green-black headlight dimmer switch to high beams
36 gray-white daytime running lamp
37 red-black headlight dimmer switch to low beams
38 lt blue-black brake feed
39 lt green-red igition switch "accessory" to alternator regulator "ign" terminal
40 lt blue-yellow manual level position sensor to EEC module
41 dk blue horn switch control
42 black-pink backup lamp
43 dk blue-yellow thermometer sensor feed
44 lt blue-orange ambient temp sensor to dash
45 orange battery feed to relay controller
46 brown headlamp switch to taillamps and side marker lamps
47 yellow-lt blue horn switch feed
48 black-white circuit breaker to seat latch relay
49 gray-lt blue htd backlite switch to time delay switch relay
50 yellow battery to load
51 brown switch feed
52 dk green power seat power feed
53 red-lt green ign sw to ign coil "batt" terminal
RoboCop
Зав. отделением пульмонологии
25
Ford Bronco II 1988,1989
Тверь
От себя тоже вброшу.
Держи .pdf со схемами на '89. Выгружал-"дистиллировал" в PDF самолично из AllData перед тем как в Красноярск за своим красным лететь. :)
дядя Алик
Бронконекромант
654
Ford Bronco 1984
Электросталь
Дима, респект!
