Любые из списка ниже, наверняка что-то есть к экзисте, автодоке и пр.
AUTOLITE 103 Resistor
Info
.054"/1.4mm
$1.19
CHAMPION 401 {#RS12YC} Copper Plus
Info
Gap .054
$1.35
NGK 3951 {#TR55} V-Power
Info
Gap 0.054"
$1.35
CHAMPION 401C2
Info
Resistor Copper Plug; .054" GAP; Plug Type: RS12YC; Copper Plus
$1.38
ACDELCO MR43LTS {#05614210}
Info
.054 Gap
$1.43
Ad
ACDELCO 19157987
Info
package .054 GAP (Only 1 Remaining)
$1.45
Add to Cart
BOSCH 7980 {#7580, HR9DCY} Nickel
Info
Gap 0.054 in; OE Is Platinum
$1.48
Add to Cart
Platinum (Lasts up to 2x longer than copper plugs)
CHAMPION 3401 {#RS10PYC4} Platinum Power
Info
Gap .054
$1.85
Add to Cart
AUTOLITE AP103 {#AP103DP2} Platinum (
Rebate/Promotion Available!)
Info
.054"/1.4mm; OE Style
$1.93
Add to Cart
NGK 3403 {#TR55GP} G-Power
Info
Gap 0.054"
$2.11
Add to Cart
DENSO 4512 {Click Info Button for Alternate/OEM Part Numbers} Platinum TT
Info
Gap .040
Choose:
($2.27) x4
$2.27
BOSCH 6710 OE Fine Wire Platinum
Info
Do Not Gap, Gap is Preset
Choose:
($2.51) x4
$2.51
BOSCH 4304 PLATINUM+2
Info
Do Not Gap, Gap is Preset; Original Equipment is Platinum [
Wholesaler Closeout -- 30 Day Warranty]
$2.53
MOTORCRAFT SP479 {#AGSF22WM, AGSF22WMF4, AWSF22E} Platinum-Nickel Plated Shell
Info
From 03/18/2002; Gap: .054; Platinum
$2.66
ACDELCO 16 Professional; Rapidfire
Info
Gap .054
$2.74
MOTORCRAFT SP405 {#AGSF22FM1, AGSF22FM1F4} Finewire Platinum
Info
Gap: .054
$3.37
Double Platinum (Lasts up to 3x longer than copper plugs)
AUTOLITE APP103 {#APP103DP2} Double Platinum (
Info
.054"/1.4mm
$3.65
BOSCH 8111 OE Fine Wire Double Platinum
Info
Do Not Gap, Gap is Preset; OE is double platinum
Choose:
($3.77) x4
$3.77
CHAMPION 7963 {#RS12PYPB5} Double Platinum Power
Info
Gap .054; OE Type
$3.96
ACDELCO 41812 Professional; Double Platinum
Info
Gap .054
$4.73
NGK 7740 {#PTR5C13} Laser Platinum
Info
Gap 0.054"
Choose:
($6.49) x4
$6.49
Iridium (Lasts up to 4x longer than copper plugs)
BOSCH 4504 PLATINUM IR FUSION
Info
Choose:
Wholesaler Closeout -- 30 Day Warranty] ($3.80)
$3.80
AUTOLITE XP103 {#XP103DP2} Iridium-Enhanced Center Electrode; V-Trimmed Platinum Side Wire; 0.6mm Finewire Design (
Info
Gap is Preset to .050"; Designed to be re-gapped to spec
$4.15
CHAMPION 9204 {#RS12WYPB4} Iridium
Info
Gap .054
$4.36
Add to Cart
BOSCH 9605 OE Fine Wire Double Iridium
Info
Do Not Gap, Gap is Preset; Original Equipment Is Iridium
Choose:
($4.75) x4
$4.75
DENSO 5326 {Click Info Button for Alternate/OEM Part Numbers} Iridium Power
Info
Gap .044
$4.80
DENSO 4714 {Click Info Button for Alternate/OEM Part Numbers} Iridium TT
Info
Gap .040
Choose:
($5.32) x4
$5.32
NGK 7164 {#2885, TR55IX} Iridium IX
Info
Gap 0.054"
Choose:
($5.58) x4
$5.58
DENSO 5087 {Click Info Button for Alternate/OEM Part Numbers} Iridium Long Life
Info
Gap .044
$8.32
NGK 97287 Laser Iridium
Info
Gap 0.054"
Choose:
($8.35) x4
$8.35
NGK 6044 {#ITR5F13} Laser Iridium
Info
(Only 1 Remaining)
$9.25
