Что на ф350 есть ? Д70 впереди ? Ну тогда ссылку в студию )))
Вот что вика выдает про передний Д70
Front axle
In general, Dana 70 front axles are uncommon, due to attributes that the Dana 60 front axle can match. The main advantage a Dana 70 front axle has over a Dana 60 front axle is better gross axle weight ratings.
Dodge and IHC Dana 70 front axles
The first Dana 70 front axle was used in 1958 by Dodge in the W300, in both 4.88 and 5.87 ratios. International started using Dana 70 front axles in the late 1960s. Both companies used Dana 70 front axles until the mid-1970s (Dodge W300 pickup up until 1978, discontinued in 1979). All of these Dana 70 front axles were closed knuckle, with king pins and had a GAWR of 6000 lbs. Like the rear Dana 70 axles, the Dana 70 front axle started out with 23 spline axle shafts and then went to 35 spline axle shafts. While these axles were being manufactured, Dana offered a "Power-Lok" limited slip differential for some of these axles.
GM Dana 70 front axles
GM began making 4x4 Chevrolet Kodiaks and GMC Topkicks that utilize a Dana 70 front axle for the 2005-2009 models. These Dana 70 axles had open knuckles and ball joints. These Dana 70 axles only came with 5.13:1 gear ratios and had a GAWR of 8000 lbs. They differ greatly from previous Dana 70 front axles, some of the major differences being the use of 1550 Universal Joints and being a high pinion, reverse cut axle.
