у меня форд эскейп 2011 акпп 2.5 литра
The following procedure will allow the PCM to learn adaptive transmission
pressure control for optimal shift quality. Complete the steps listed below:
NOTE: Clear Keep Alive Memory (KAM) before performing drive cycle. Use a scan tool.
NOTE: The engine and transaxle must be at normal operating temperature.
1. With the engine running and the brake applied, move the selector lever through the gears
in the following order, pausing in each gear for 4 seconds: N, R, N, D, R, D, N. Repeat
this pattern 2 times. If any engagements feel soft or harsh, repeat this procedure.
2. Drive the vehicle and accelerate at a moderate throttle so that the upshifts occur at 2000
rpm up to 50 mph (80 km/h) and brake lightly to a stop. Repeat this pattern 2 times.
3. Drive the vehicle and accelerate at a moderate throttle so that the upshifts occur at 3000
4. With the engine running and the brake applied, move the selector lever through the
gears in the following order, pausing in each gear for 4 seconds: N, R, N, D, R, D, N.
5. From a stop, accelerate to 25 mph, and then release the throttle. Keeping the throttle
closed, pull the selector lever into the “L” position and coast down to 10 mph. Repeat
the pattern 2 times.
ВНИМАНИЕ! Для корректного выполнения процедуры требуется выполнять все инструкции в точности так, как они изложены!
